Having trouble with Cura 5.1 not detecting a bridge
FTsabrovAS
Posted · Having trouble with Cura 5.1 not detecting a bridge
Hello all,
I'm trying to create a geometry that can be printed support free over a square nut or over thin air. I've made what is in the attached image, with two layers intended to bridge the gap before printing the hole above. I intended for this geometry to be a bridge, but Cura 5.1 is not detecting it as such. Is there something I'm doing wrong?
Default bridge settings turned on
~8mm wide square hole
~5mm wide round hole
0.15mm "steps", same as my layer height
0.4mm nozzle on my S5
    Did some more experimenting- the bridge is detected if I increase the bridge skin support threshold from the default 50% to a whopping 95%. I suppose it is counting the surface area overhanging relative to the surface area of the previous layer, not just localized to the overhang. I suppose this works for the piece I am printing now, but is there a downside to keeping this value this high?
