Here we go - not completely mounted as the heating pad is still missing, but it works...
Needed 9 sections parts between bottom and bed end to fulfill the task (maybe I´ll add one more later on) :smile:
First of all, thanks drayson for adapting IRobertI's cable chain for the UM1! I implemented it with my new heated bed using 10 chain segments:
However I had to modify the bed end part (yellow). With the original design, the radius for the chain segments was too small. Thus, I added 10mm on the bed end part and also moved the screw bore by these 10mm in order to get a larger radius for the chain segments. It works nice this way...
Hi!
Great adaption!
I have not mounted my heater pad yet so I had no chance to check the bendig behavior of my original cables - just tested it with some other cables and there it worked.
Would be great if you could also publish this modified part. :-)
Hi!
Great adaption!
Would be great if you could also publish this modified part. :smile:
Oh, sure... the stl is here. Please feel free to include it in your published set on Thingiverse if you like it. I think there is not much sense in opening a new set on Thingiverse for such a minor modification.
Thank you, I will add it of course with reference to you.
IRobertI 513
Sweet
Looking forward to seeing what it'll look like mounted.
