Generic PETG missing from Materials Manager in 5.1
We don't have a material profile for PETG for the Ultimaker 2+, since we released Ultimaker PETG after the Ultimaker 2+ has been discontinued.
But if you know which temperatures you have to use, which are often on the packaging or on the website, I suggest to make a New Material based on CPE since that one is most similar. Make sure you type CPE as Material Type for the layerheights to work. After that you can tune the other settings as much as you like (except for changing the diameter of the material)
Good luck!
Edited by MariMakes Forgot to mention about the material diameter dissapearing if it's too low
1
MariMakes 199
Hey @dk-info,
Welcome to the community 🚀
Edited by MariMakesBut if you know which temperatures you have to use, which are often on the packaging or on the website, I suggest to make a New Material based on CPE since that one is most similar. Make sure you type CPE as Material Type for the layerheights to work. After that you can tune the other settings as much as you like (except for changing the diameter of the material)
Good luck!
