Hey Mari, thanks for the quick answer !
Sure I can split part in Cura when they have distinctive boundaries (even in STL :p), and then move them so that I can close the gap, but doing so, I loose the actual Z dimension of the whole part. I could increase the Z scale of the 2 elements to "share" the scaling and keep the global Z OK, but then any useful features such as mount interface on the flank would also be scaled up and not perfectly round for instance.
In addition, I commonly have dozens or more parts, which would be not very convenient to manually offset / scale.
Would be really nice to have a feature directly inside the CURA Correction section, to close vertical gap within a tolerance 😄 Sure It would not be the perfect solution as it might close some fine details that are actually interesting. Let's say for instance letters on a XZ or YZ face, an "S" ou an "E" letter that would be writter too little, would probably trigger the function and close the gap between the thin separation of the letters. But hey, nothing is never perfect haha, and with some zoning it might help a lot.
It would also be some kinf of Z Expansion, I've always found weird that the option does not exist (not of my knowledge, at least) : This Z expansion would apply to any XY surfaces (parallel to the bed) so that it would extrude them by some 0.XX mm, just like we do it with horizontal expansion. But it would need an option to keep the exact external silhouette dimensions : the upper XY horizontal surfaces and the lower XY surfaces should not expand anymore, only in the direction of the center of the part. That would probably do the trick, without requiring too much attention as a user.
Edited by Dadkitess
MariMakes 167
Hey @Dadkitess,
That's an interesting challenge. 😮
Do you understand your question correctly?
You have an assembly in your CAD program and you want to print a prototype to get a feel for the size and fit. But when you export your model it comes with a significant zgap.
Have you considered exporting your assembly as an .3mf instead of an .STL? In my experience you are can still manipulate the individual models if you do so. You could than drop the model a bit to remove the zgap.
I also fidgeted with 2 support meshes.
This is the closest that I could come to a solution.
Mari_AssemblyChallenge.3mf
That's as far as my knowledge goes.
So if it's not what you are looking for, let's hope that there are others that have a different point of view.
Fingers crossed 🤞
