Here it is
GregValiant 1,112
Thanks.
I made a couple of changes I thought might help and I'm attaching my effort. It looks pretty good and I don't see any moves through the interior of the tube.
I moved the part so the bottom of the gooseneck is at about the midpoint of the build plate. Using "Z seam relative" with the location at X0 Y0 puts the Z seam direction at the midpoint of the part. When the part splits and start printing as islands the Z seam of both islands face inward towards each other. I did the same with the Layer Start X and Y.
Enabling "Avoid Supports When Traveling" also made a difference for the area where the lower support has split into islands. I set the "Travel Avoid Distance" to 3mm.
Thank you, very interesting. About 3 traveles remain, when support structure begins to split. Depends from type of support. I will try
GregValiant 1,112
The best I've been able to do is 1 move across the tube and it has to do with the support. I moved the Z seam and layer start to the left front corner of the build plate.
Edited by GregValiant
Wow @GregValiant to the rescue! Amazing. 🎉
I have nothing to add except maybe if you want to learn more about what the different settings do you can install the Settings Guide from the marketplace: https://marketplace.ultimaker.com/app/cura/plugins/Ghostkeeper/SettingsGuide2
In this case I would specifically look at Combing.
Good luck and happy printing! 😃
GregValiant 1,112
Load up a model, prepare your Cura settings for slicing, and use the "File | Save Project" command. Post the 3mf file here.
