MERGE !?!?
JTMD
Posted (edited) · MERGE !?!?
OK.. what are we supposed to do with the image of the models?
It would make it easier to help you if you could post a link to the STLs and/or post a small video of what is happening.
Edited by ahoeben
    Hey @JTMD,
    Merging is very dependent on the way that the file is generated.
    Did you design it yourself? What program did you use?
    The best way we can help you is by sharing a project file.
    To save a project file go to File -> Save project. Please make sure to .zip your project file.
