Posted · Travel line stringing
Hey @jvl,
Thanks for sharing your problem and the project file.
Your settings seem fine. These are all light blue lines, so they should be retracted.
Nylon is really prone to stringing once it has absorbed moisture.
When did you open the spool? Could it have absorbed a lot of moisture over time?
You can try drying the spool on the buildplate.
The feeder tension could also be off. Is it in the middle?
