thank you for the suggestion Mari,
Yet I used to work around the issue in a simlar way and it always resulted in 2 lines.
As a reference I will show you the sliced results with an 1mm box.
and if I make the boxes 0.1 thickness then this is the sliced result
Is there anything else we can try to get the stiffners to be sliced as single lines?
MariMakes 201
Hey @printnewb
Welcome to the Ultimaker Community 🚀
Thanks for sharing your model.
This mesh seems faulty. All the non yellow parts indicate open walls.
![image.thumb.png.575f48bcff27eb87946e0f656a6a2256.png](//content.invisioncic.com/ultimake/monthly_2022_10/image.thumb.png.575f48bcff27eb87946e0f656a6a2256.png)
You can only 3D printing with watertight models,
If you want single walled models, you'll have to build a wall with the same width as your nozzle. In your case, 1.0 mm.
I believe if you redraw your dividers to be 1 mm wide, you should see way better results.
