Posted
· different infills within the same model possible?
You can bring in a support blocker, scale it to fit over the area you want to change. With the blocker selected go to the Per Model settings and set it to "Modify Overlaps" and as an Infill Mesh. Use the Select Settings button and go down to the Infill section and select "Infill Density". Now you have a Modifier Mesh.
You will get extra top and bottom layers at the intersection of the blocker if you don't set them to zero.
You could also add more walls at the overlap area instead of increasing the density of the infill.
Here I've done both. The mesh modifier is set to 100% infill and 3 walls.
Posted
Another option is to tweak the "Minimum Infill Area" setting. That way you would get 100% infill with skin pattern in the leg. And if you find a value that fits well with the model it would do the same thing to other parts of the model that could also turn out too small to work with the 20% infill. 100% infill instead of 80% shouldn't make that much difference in print time and material use on such a small model, but it will probably be stronger.
GregValiant 1,318
GregValiant 1,318
Cutting back on that models beer intake might help in the long run.
