Hey @Derrringer,
Welcome to the Ultimaker Community 🎉
There are actually some settings that would limit your buildvolume that you can change or disable.
A compresive list can be found here: https://support.ultimaker.com/hc/en-us/articles/360013799339-How-to-print-the-maximum-build-volume-in-Ultimaker-Cura
Would this help you to reach the buildvolume you are looking for?
1
Derrringer 0
All, this is still an issue but less urgent. I downloaded Prusa's Slicer and the parameters are less restrictive and I was able to produce a gcode and that's almost done. I still think I'd prefer to use Cura, so I hope the Devs can provide a workaround for the future (especially since the 286mm part I needed is printing just fine through Prusa).
