Sliced model not hollow
catprint
Go to solution Solved by obewan,
Posted · Sliced model not hollow
Hey @catprint,
Welcome to the Ultimaker Community 🎉
That looks like a cool printjob.
Do you have a project file for us? It contains the printer and settings we need for troubleshooting.
To save a project file go to File -> Save project.
It could be that your mesh is faulty.
Have you tried doing a quick mesh fix with the Meshtools Plugin?
You can get it here: https://marketplace.ultimaker.com/app/cura/plugins/fieldofview/MeshTools
    Surface Mode has a chance of working, but that's a really bad model.  MS 3D Builder and Mesh Mixer were able to repair it, but it ends up as a solid with no openings.
    Online STL repair gave the following report on the model:
    --> Analyzed your file:
    --> 776 Naked edges (?)
    --> 17 Planar holes (?)
    --> 13 Non-planar holes (?)
    --> 202 Non-manifold edges (?)
    --> 218 Inverted faces (?)
    --> 0 Degenerate faces (?)
    --> 0 Duplicate faces (?)
    --> 0 Disjoint shells (?)
    -> Vertex count changed from 31902 to 33613 (+1711)
    -> Triangle count changed from 63191 to 67556 (+4365)
    Here is the X-Ray view of the original model showing large areas that have errors.
    Here is the repaired version sliced.  It doesn't look much like the original model and the top and bottom aren't flat.
