- Solution
Hi MariMakes
Yes that was exactly the right answer. Thank you very much.
It must have been removed when I upgraded from 5.2 to 5.2.1 as it was working with 5.2. When I installed 5.2 the plugin came across from the previous version 5 (and from 4 to 5), so I would have expected it to transfer to 5.2.1.
Anyway got it back.Again many thanks.
WartyNZ
1
MariMakes 201
Hey @WartyNZ,
Could it be that you had the printscreen on the left before and now just the printscreen on the right?
It could be that you had the Settings Guide installed but it has been disabled, or unistalled somehow.
If you click the gear icon in the marketplace you can see which plugins you have installed.
If it's disabled you can enable it, and if it's missing you can install it.
Was this the answer you were looking for?
