the location hasn't changed, the only think I see is that the axes (E X Y, z etc) was changed to lowercase! (e, x, y, z)
and I do note that the manual has it in upper case.
though I would recommend making a file in
/var/lib/griffin/machines as this is kept between updates to firmware.
you can put a um3.json file in there that inherits from /usr/share/griffin/griffin/machines/um3.json so that it changes only those properties (or use the specific filename for your printer model as I've done in the attached file).
so you should be able to copy the attached file to /var/lib/griffin/machines (after you run mkdir /var/lib/griffin/machines)
robinmdh 108
good luck either way!
9066.zip
RaphaelOst 8
Thank you @robinmdh
