Hi @dsp...
These were printed simultaneously but I've done many individual prints. At 2% fan speed it's even worse than the worst of this bunch. I have tried it with multiple ultimaker ABS filaments and multiple ABS's in general. I have often wondered if I have a broken thermal measure but I think(?) those are in the print cores and I have these problems across print cores too.
<sigh) About every 6 months or so, I seem to get serious about trying to dial in this printer and then I get discouraged and the cycle repeats 6 months later. </sigh>
Trying to Understand S5 Calibration Print Failures with Ultimaker ABS
ABS takes some time to get used to and the biggest drama is that you need to change the setting depending on the model you are printing.
One of the reasons we lately went over to ABS pro, this is a lot more forgiving as normal ABS.
1
Hey @cheuschober,
I asked our Material Profile experts and they reccommend only using your fans for the first layer of briding an area.
Using the fans at other times will just limit your bed adhesion.
The outerwall bridge lines seem to have broken and have fallen down in a specific orientation. They probably get too thin while pulling and break. Make sure that your speed changes are minimal while bridges.
The difference in tower orientation can be due to the asymmetry in the cooling profile while moving over the trace. The assymmetry has to do where the fans are located on the printhead.
dsp 20
If i understand correct this is 3 times the same model and settings only a different location?
did you try and print them one at a time as well?
I noticed ABS is really sensative when it come to cooling time, some of our small prints need to be printed with mutiple models at the same time. While with the same settings and filament we don't want to fill the entire base plate wit mutiple models because it get to much cooling time.
also I think 50% fan speed is a lot on ABS we usualy print at 2% fan speed
