Ultimaker 2+ switches off depending on material selection
Posted
· Ultimaker 2+ switches off depending on material selection
Great news. Since you already installed tinkermarlin you can do a quick test.
These power bricks tend to fail where they can't put out as much power as they used to. So you can lower your power usage by say 50 watts. In tinkerMarlin there is a feature "power budget". By default it should be:
budget: 175W
bed: 150W
nozzle: 25W
With the above values, the power budget does nothing. Try using the same values as above but lower the budget to 120W. This difference (175 - 120) should be more than enough for all the servos. If this works then you can increase the budget by 10W every minute until you find the point where the power brick (and printer) reboots. This will prove it's the power brick (in my opinion). Then you can choose to run the printer on a lower power budget (you might have trouble getting the bed hotter than 80C) or you can choose to get a new power brick.
gr5 2,210
budget: 175W
bed: 150W
nozzle: 25W
