GCODE from CURA with custom printer always contains a first extra layer.
Posted
· GCODE from CURA with custom printer always contains a first extra layer.
The outline may the the "Skirt" feature (or brim or raft) and the settings are in the Bed Adhesion section of Cura. The default distance from the model to a skirt is 10mm.
Brims are intended to be attached to the model to provide additional adhesion to the bed. There is also a "brim distance" setting that will offset the brim from the model at which point you once again are back to a skirt.
Both brim and skirt have width adjustments.
A raft is thick and provides a very solid base for a print but must be broken away from the model as the entire base of the model will rest on the raft.
An option is to shut them off. The point to a skirt is to get the material flowing well from the nozzle before the actual print starts. For myself I use a skirt for most things and set it to 3 loops and 3mm from the model. If I want better bed adhesion I go to a brim. If the model starts with a large flat area I use "None".
There is a slider to configure the settings as "Custom". When in Custom - next to the Settings Search box is an icon with three lines (hamburger icon) and it is the Settings Visibility tool. Set the visibility to "All" and those Bed Adhesion options will be available.
GregValiant 1,318
