Oh yeah, I've been having issues with the extruder. Mostly over extrustion that's messing up my prints, but only at a 45 degree angle. I can literally watch it pause for a moment and push out an extra little blob of filiment (this filiment printed out models perfectly on my Tina2). I need to figure that out next, I've only been using this printer for three days. I've fixed the gap issue, I just had the nossle set too high. Totally new to the whole levelling a printer myself, the auto leveller does crap all.
See, that's what I thought as well, layer shift, but it's printed two models as one perfectly, which is very confusing. Now, I tried slicing and printing Totoro last night and it printed fine, apart from it over extruding at the 45 degree angle, so I'm thinking cura just can't slice these files. Thankfully it isn't something I've made causing the issue, I just downloaded the file. I've tried editing the file in blender and then printing it, but I get the same results.
Ok, so I just attempted to print Pokemon badges, same exact results, it's screwing up badly in the exact same way. I let it put the first layers down for most of them and could see they were off. Nothing symetrical. I really don't understand. No matter what version of cura I use, including the one on the SD card that came with my printer, I get the same results, messed up models.
Edit 2: I don't think it's cura causing the issues. I just took another look at the benchy I printed on day one and it has the exact same issues all my other prints have.
Edited by ZankiAdding more info
GregValiant 1,318
That is pretty bizarre.
To start though - the prints are severely under-extruded. When you zoom in to the images you can see that the extrusions aren't welding together. Did you calibrate the E-steps on the printer?
That was the easy part.
The other problem looks a lot like a layer shift but the way the models are orientated on the build plate I don't think it can be.
Load them up and set Cura up to slice and then select the "File | Save Project" command and post the 3mf file here.
The Cura slicing engine and the gcode reader are separate apps so you can also open your Gcode in Cura and see how it looks. I'm pretty sure that "double-vision" thing won't show up.
