On 11/24/2022 at 5:12 PM, gr5 said:Please post a picture. 90% of issues with PVA is due to insufficient drying. Despite using lots of desiccant I have to dry my PVA before every print. I set the heated bed to 60C.
I look in cura to see how many meters are needed (in bottom right corner hover over on the "i" in the circle).
Then I unspool that much and put it on the hot glass with the spool on top of that. Let it dry for 4-8 hours before printing. You should see different results.
Wet PVA prints snowier. Whiter. Dry PVA is clearer. Very wet PVA sputters and crackles and you can see the steam.
Dear gr5, everyting working fine so far, after heating and drying PVA Natural as you adviced. Here you have some pictures. Thanks a lot,
E.
1
gr5 2,094
EPALMI 2
Thanks a lot gr5, We'll proceed following your advice in our next prints. I'll post a picture.
