Cura 5.2.1 Preview slider not working
Go to solution Solved by waitee,
Posted · Cura 5.2.1 Preview slider not working
Using Cura 5.2.1 have issue when after slicing  on the Preview tab unable to move the slide on the right side to preview each layer.
It hangs and show the hour glass.
Printer selected is CR10-S, PLA material. Standard layer quality
    Hey @waitee,
    Thanks for your report 👍
    This is the first time I've heard of this issue.
    I'm sorry you reverted to 4.13, you are missing out on some sweet features in Cura 5.2.1 like the variable linewidth.
    What kind of computer set-up do you have?
    Were you running any other programs in the background?
    Does this behavior show up with multiple project files of just with this one?
    I am running Cura all for a very long time and update once it is available . Since using 5.2.1 encounter this problem when doing preview even with one file or project being loaded, it will take a long time to move from layer to layer. Running 4.13 does not have this problem.
    My system is AMD Ryzen 7 5700U with Radeon Graphics   window 11 Home version .  It happen even without other program running in the background.
    • Solution
    13 hours ago, MariMakes said:
    Hey @waitee,
    Thanks MariMakes
     I have found the problem - my recent Window 11 updates  is the issue nothing to do with Cura - apparently Window 11 update of its files get corrupted so I repair the updates and it work.  The update also cause alot of problem in my other software like meshmixer and sketchup.
    Oh wow! Thanks for the update!
    I'll keep it in mind if I encounter similar report.
    Happy Printing 😄
