When the nozzle clogs on mine, I take it out and use a propane torch. Blasts everything out of there in like 5 seconds.
- 1 month later...
As a follow up on this clogging problem, which I had for almost a year, I seem to have finally cracked it, or at least made it better. I printed this filament cleaner http://www.thingiverse.com/thing:133353,%20but%20instead%20of%20using%20a%20sponge,%20I%20use%20tissue%20paper%20that%20I%20switch%20out%20whenever%20I%20switch%20filaments.%20I%20have%20had%20one%20partial%20clog%20in%20month%20of%20printing%20since%20the%20change,%20where%20previously%20it%20would%20be%20multiple%20clogs%20per%20week.%20Phew!
gr5 2,210
I think you mean "Ultimaker Original" and "Ultimaker2". The nozzle on the 2 is totally different with a built in heated chamber so definitely not compatible. I've seen many nozzles on ebay that claim compatibility. About $2 each I think. I haven't tried them.
Do you have a very dusty environment? Dust can climb up the filament and get into the nozzle and cause clogs. Or wood particles.
