I also had a fan issue which ended up being very fine strings of material caught in the inner bearing of the fan, i had to remove the fan which is quite difficult and you risk breaking some solder joints, its easily repaired though with a soldering iron. I removed all the material of which there was A LOT compared to what i could previously see. Everything's been working fine for months after this.
MariMakes 201
Hey @FSund,
Welcome to the Ultimaker Community 🎉
Hardware replacements are not my strong suit.
But I do have access to the assembly manuals.
UM3 - Replacing the axial fan.pdf
If that doesn't work there might be a broken part.
Then it's better to reach out to our support experts.
You can create a ticket here:
https://support.ultimaker.com/hc/en-us/requests/new?ticket_form_id=360000516360
