It sounds like you opened a gcode file instead of a model file. If the Layer Slider works without having sliced it then it's a gcode file. You can also open that "bad" file in Notepad and see if it is just a mis-named Gcode file.
Try another STL and see if it will slice.
A year after the merger of Ultimaker and MakerBotQQ, we have unlocked the ability for users of our Method series printers to slice files using UltiMaker Cura. As of this release, users can find profiles for our Method and Method XL printers, as well as material profiles for ABS-R, ABS-CF, and RapidRinse. Meaning it’s now possible to use either Cura or the existing cloud-slicing software CloudPrint when printing with these printers or materials
GregValiant 1,142
