On 12/2/2022 at 10:15 PM, elnadav12 said:Looks like severe under extrusion...
What are your print settings? (temp, speed, layer height etc...)
Have you tried cleaning your nozzle?
https://support.makerbot.com/s/article/1667337917259
Hey elnadav12. Thanks for answering!
About the print settings: I don't really go deep on it, I'm always around the "recommended" tab on Cura. For this piece, layer height was the 'normal' option (0.15mm) and infill 30% with support. All the rest were handled by Cura.
The nozzle was cleaned also, but we have a brand new one here, we will try to change it and test it!
Also I noticed that the material that is inside the printer is always coming out with some sort of scratches on its surface, and even some of it falls, in a powder level almost every time i change it, falling from inside the feeder. Maybe this is where the issue are!? I will try to open it and check it, but I am afraid to mess it even more.
Do you know if I can find an image of the feeder opened? I would like to check for reference!
elnadav12 3
