- Solution
GregValiant 1,318
"...this issue is caused by some slicer setting(s) that somehow modifies the mesh to create this particular defect."
So far as I've been able to tell Cura can't do anything to the mesh itself. In this case the outer walls of the first 5 layers have no overlap. It isn't until layer 6 that the new outer wall overlaps the outer wall of layer 5. That means the outer walls of the radii near the build plate are going to sag. TAN(OverhangAngle) * Layer Height = Step Width and when the step width is greater than the Line Width then there is no contact between the Outer Wall extrusion and the layer below. It is going to stick a bit to the inner wall that was laid down previously on the same layer, but gravity is going to win.
Looking closely at the last image you can see that starting with about layer 7-8 then outer wall stays where it was put. No more overhang there.
Having your "Outer Wall Inset" at 0.2 isn't hurting anything but isn't helping either.
Arc Welder will not work with these radii as they are in the wrong plane.
These are PETG on a stock Ender 3 Pro. The inside of the radii look good to me. I printed this one with support so there is some scuffing from the exacto knife where I removed the support.
The top print was without supports, and I got that divot/chamfer look. It's because the "overhang" of the first 5 layers have no "overlap" with the layer below and so those outboard extrusions sag and give the impression of the divot/chamfer. The plastic is there - it just didn't stay where it was put.
- 1
ahoeben 1,965
Try printing it standing up...
It looks like this is simply caused by overhangs not printing well without support. But even supports won't be a magical fix; sometimes you just have to design for 3d printing, or adjust the printing orientation to get the best result.
Edited by ahoebenLink to post
Bubble 1
Thanks @ahoeben, but that's not the case. I say this with confidence because as part of the testing process, I printed the exact same model in so-called 'vase mode' (aka 'spiralize outer contour'), and it printed very well without supports. In other words, the defect I was talking about was totally gone and the edges came out nice and round throughout. This mode is of course useless for printing this particular model as it only creates the outer shell, but it does clearly indicates that the overhangs are printable without supports and further strengthens my theory that the printing geometry created by Cura is the source of the problem in this case.
Edit: I should probably clarify that the part I'm discussing here is just a very simplified version of the part I'm actually aiming to print. The reason I use this simplified model is to isolate the issue and hopefully make it easier to pin down and solve. Hence, while it would probably make sense to print this simplified model standing up and circumvent the problem as you suggested, that won't work with the actual part I have in mind.
Edited by BubbleLink to post
