Save to removable saves on HDD anyway... Cura 5.1 and 5.2
Posted
(edited)
· Save to removable saves on HDD anyway... Cura 5.1 and 5.2
Hello again!
I use Windows 11 x64. Yes, my operating system is not English language. Yes, SD card worked before. This happened during one session with the program. I don't remember exactly how it happened, but something like: I saved gcode to the SD card - OK. A moment of work, I saved the gcode, this time to disk - OK. Another moment of work and saving again on the SD card, but... This time, gcode was written to the computer, same drive I was saving to before. And it's always been like that ever since. No, I have no more devices in the card reader, if that's what you mean.
I think it might be caused by one of the plugins. I have to check it out. I use "custom printjob naming".
Edit:
I'm back home and checked. Thank you MariMakes!
Your questions led me to the idea of checking plugins. And that was indeed the reason. No idea how, but one setting of plugin "printjob naming" was set to save to path D:/. This plugin catches saving process and replacing the name. And the path in this case. Now all works as before.
Edited by nepcior New information
2
A year after the merger of Ultimaker and MakerBotQQ, we have unlocked the ability for users of our Method series printers to slice files using UltiMaker Cura. As of this release, users can find profiles for our Method and Method XL printers, as well as material profiles for ABS-R, ABS-CF, and RapidRinse. Meaning it’s now possible to use either Cura or the existing cloud-slicing software CloudPrint when printing with these printers or materials
GregValiant 1,141
Hello @nepcior.
@MariMakes should be able to help with this when she gets a moment. She will need to know more about your computer and operating system.
Cura makes calls to the operating system to handle file writes so maybe something is going on between them.
Is the "lock tab" on the memory card in the "write" position?
MariMakes 192
Hey @nepcior,
Welcome to the Ultimaker Community 🎉
That's odd. 🤔 It reminds me of this github issue but it seems different.
I have a bunch of questions!
Which operating system are you running?
Is your operating system in a non English language?
Did this SD card work before?
Do you have more devices plugged in?
nepcior 2
Hello again!
Edit:
New information
