Cura 5.2.1 - Subtracted embossed text showing extra lines within the subtracted area of text.
Go to solution Solved by ahoeben,
Posted · Cura 5.2.1 - Subtracted embossed text showing extra lines within the subtracted area of text.
Hi All
Using the following;
Win 10 PC,
Cura 5.2.1,
Matter Control to create object.
I am trying to create a sign with a front and back face.  The text is a copy of the other, copy & paste, so it has the same font, spacing and size configuration.  The bottom side the text is mirrored and the top side normal.  When I slice the project as you can see in the pictures attached the bottom side text has some extra lines (in light blue) within the embossed/subtracted area.  This is not seen in the top side text?
I am new to printing so the error that was displayed doesn't mean much to me in fixing the problem.
I have attached a copy of my STL file, top side, bottom and closeup of bottom side, any comments greatly appreciated.
Thanks all.
PE.stl
    • Solution
    The blue lines here a brim lines. This happens because these letters have an "island" inside them, and Cura gets a little confused about what is the inside and what is the outside of the first layer.
    Since this print is very round, you could try printing it with a skirt instead of a brim.
    • 1 month later...
