Ultimaker S5 - Unknown Build Plate Type
Go to solution Solved by MariMakes,
Posted · Ultimaker S5 - Unknown Build Plate Type
Hi there - using my new UMS5 Pro Bundle. When selecting a print (sliced in cura) on my flash drive, I have green check marks for everything ACCEPT "unknown" build plate type. Do you know what is causing this? Is there a way to change this setting in Cura? I cannot find a setting that enables me to specify build plate type when slicing. I am using the standard glass plate - which I specified during printer set up.
    • 1 month later...
    • Solution
    Update!
    A new version of the firmware became available today that has a fix for this. 🎉
    You can check your printer or you can download the latest version of the firmware here.
          • Heart
        • 7 replies
