Will do! Thank you in advance.
Here is my 3mf file. this is more the standard settings. I have tried lowering the expansion and lowering the flow. I have not calibrated esteps, but will do that this evening.
GregValiant 1,317
That model is all about Flow and Line Width and the two go hand-in-hand.
If you are in the "Basic " Cura settings then select "Custom". The button to the right of the "Search Settings" box is the visibility control. Click on it and set the visibility to "All".
Get your E-steps squared away (that has a direct effect on Flow) and then set your Quality / Outer Wall Line Width to .35. You can leave the flow settings at 100% for now but if another test shows that the sections are still getting bonded together then drop the flow to 95 or even 90%. Since neither the layer height nor the extrusion length can change then flow can only affect how wide the extrusions are.
Another setting you could use is Horizontal Expansion. If you set it to a small negative number like -0.05 the gaps between the pieces will get larger.
"Everything affects Everything" so look at the preview closely. There seems to be plenty of room between those pieces and there really shouldn't be a problem.
Thank you very much for the help. I will try your suggestions. I did checked and set my E-steps first and they were actually a little low. 100mm of requested filament was giving me 95.5mm. I set it to give 100=100 (by changing my steps/mm from the stock 93 to 97.3.
I am now printing some test bocks with 1, 2, and 3 lines. I will try the 0.35 outer wall line width.
Thank you again for your help.
GregValiant 1,317
Load the model and set Cura up for your slice. Then use the "File | Save Project" command to create a 3mf project file that will contain the model, your settings, and your printer. Post the 3mf here and I'll take a look.
Usually it's the flow though. Did you calibrate the E-Steps on your printer? Most Enders require that they be calibrated.
