Thank you gr5 for your answer. the thing is i want use the revo heater core on my ultimaker original plus but the don't use pt100 thermistors.
But as i understand you this board and thermistor is not the best combination, maybe better switch to a duet3 mini 5+ wifi board or do you advise me anything else?
gr5 2,094
Marlin is expecting a very simple circuit where there is a 4.7k or 47k (depending on which sensor table you use) resistor in series with the temperature probe. But the Ultimainboard V2.1.4 which goes on the UM2 printer has an op-amp circuit that is much more complicated and designed specifically for PT100 resistors. I recommend PT100 resistors as they are great. They are cheap, can be tiny, and come in all kinds of sizes. And every PT100 resistor table is identical to every other no matter the manufacturer. Unlike normal thermistors.
However it might be possible to create your own resistor table. Maybe. I'd look at the circuitry first and figure out what resistance results in what voltage at the "arduino" first and then from there you could use that info plus the thermistor table you have. You might find that when the temp gets above or below a certain temperature you are at the full scale reading of the ADC so it might not be possible.
