No, here at the Ultimaker forums we tend to recommend other brands
Speed depends on what you're trying to do, how thick the layers are, which printer (UM original or UM2) and what material you're using. In general though I think most people print around 30-90mm/s depending on if you're printing for quality or speed.
15 microns (0.015mm) is insanely thin, I don't think anyone prints that thinly on a daily basis or if it's even possible. In my experience I think going below 60microns is a waste of time as you don't really gain any quality. 99% of what I print is at 100microns.
Like that though i have tried 0.02mm once..... you tend to get some real problems with how the plastic behaves at that layer thickness... it is partial unreliable and will give you a worse surface than 0.04mm
IRobertI 516
