GregValiant 1,309
In Preveiw mode, if you look at the underside of a model you will see surfaces colored red. Those are the areas that will need support (according to the overhang angle you set). Those red areas must be covered by a support blocker in order to block the support. The blocker doesn't need to go down to the build plate, just cover the red surface, or in some cases, part of the red surface.
Here there are three blockers that I've made 30mm in the Y
There are no supports where they've touched the red overhang surface.
- 1
nallath 1,123
You can use any shape for a support blocker. Just add any object and check out the options in the per object settings tool 😉
MariMakes 199
Hey @Herlock,
Welcome to the Ultimaker Community 🎉
@nallath is right, you can turn any model into a support blocker, and you can move and resize it like any other model.
Here is a quick demo:
Hope this saves you some time in the future 😅
Herlock 0
Thanks @nallath and @MariMakes !
So I tried and it doesn't seem to be working : That medaillon is set as "don't support overlaps" like in your demo, but supports are still generated. I tried with other models I had available, no better luck.
If you don't mind me insisting : resize handles on the regular support blocks is propably more user friendly, although I appreciate that there is a way to do what I am looking for (even I can model a cube in fusion). Well that is if I can understand how to make it work 😄
