I also print cutters and know exactly what you are experiencing. It is the build plate you are using. I was using an Ender PTEG magnetic flexible build plate which has texture but you could still see the lines. I now use ANYCubic magnetic flexible metal build plates and lower my z axis just a touch more so it really imbeds the first layer into the texture. Doing so I do go through hot ends faster but I don't have any lifting off the build plate ever and I have this wonderful texture instead of lines.
1
MariMakes 208
Hey @agraves,
Welcome to the Ultimaker Community 🎉
What a super cool application.
Looking at the white printjob two things come to mind.
It's either 3D printed using a different technique like Binder Jetting.
OR they use FFF 3D printing but they have a different buildplate than you do.
If you want a unique look to your initial layer you can also consider 3D printing on Holographic sheets.
If you end up trying this technique, let me know! It's one I really want to try 🤩
