Well, there are other options now too, such as Moonraker/Klipper, and some other brand-specific plugins. But only very few of those will integrate with the "Connect to IP Address" dialog you see when first adding a printer to Cura, That part is indeed mostly just for Ultimaker printers.
AFAIK, the Creality Cloud plugin (https://www.crealitycloud.com/post-detail/7865) connects via the cloud and using that you will not need to enter an IP address for the printer; the cloud takes care of that. But support for that plugin really needs to come from Creality; I only know that the plugin exists.
1
gr5 2,210
Through ethernet, Cura will only connect to Ultimaker products and also it can connect to octoprint. But that's it.
