- Solution
@Noppi do you have coasting enabled? It stops extrusion a bit before the actual end of a line to release pressure in the nozzle, this is mostly relevant for bowden extruders to prevent stringing. It shows in the GCode just like it does in your screenshot.
1
RogueWave 15
My experience tells me the model geometry is in question. Look over it in a render or wire frame mode
