Print Core is it Clean or Frosty Snowman in Town
RogueWave
Posted · Print Core is it Clean or Frosty Snowman in Town
After several, several, several  times cleaning core, it still is a pit frosty in color. The tip is OK, broke off by me. Surface is smooth by touching and under magnificent looks fine....no rough surfaces....
Thanks
    Hey @RogueWave,
    Is your question if the tip is clean enough?
    I guess it depends on your printer and filament.
    A reason that your tip is frosty can be the texture inside of your nozzle.
    Or the kind of material you are using....
    Hope this helps
        • 4 replies
