GregValiant,
I think I have fixed the problem. I installed extensions and among them is an 'Post processing' > 'Modify G-Code' where the following preset code was installed (See the attached file).
So the temp was set to 230° and decrease by 10° every 7 mm.
Sorry for that !
Thank you for replying to this post !
1
GregValiant 1,330
As you know that should not have happened.
Post the problem gcode file here and someone will take a look.
Are you printing from the SD card, using Octoprint, or printing via USB??
