Hi MariMakes,
Thank you for your quick reply.
I have attached the project file of my coupling ring.
when I was playing around with it some some I have noticed that the lines get longer if I would increat the infill layer thickness, and it only seems to support the top layers... maybe it is just a feature.
But if I select concentric infill, only the walls are printed...
MariMakes 201
Hey @touwen75,
What an interesting case. 🤔
What are you using your model for?
Have you considered using lightning infilll, it speeds up the printtime a lot!
Do you have a project file for us? It contains the printer and settings we need for troubleshooting.
To save a project file go to File -> Save project.
