Settings for quick print profile normal quality
euan
Posted · Settings for quick print profile normal quality
I have had a look through the forum and can't find an answer to this, but apologies if I've missed it!
Since I got my UM2 I've been using Cura on the quick print profile and normal quality and have had great results. I'm now starting to print some bigger parts and would like to try and speed them up a bit.
What I'd like to do is to switch to using full setting but start off with all the values from the quick print normal quality and then modify from there. Are these available somewhere? I was planning on reducing the fill density a bit and increasing the speed slightly.
    Just switch to full settings, and then go to the file menu, and do 'Load Profile from gcode', and pick one of your quickprint-sliced files. That will load all of the settings that were used.
    quickprint settings are different in different versions of Cura so that will probably never be posted and if it is it may be wrong a month later.
        • 24 replies
