I'll take a look at my settings. However, .......
I've been printing with fan disabled - that seemed to be the abs standard, based on my reading/previous prints.
Current setup is for bottom layer at 1/2 speed. I've had best results at 80mm/s for upper layers which would mean 40mm/s for bottom layer. Lower print speeds seem to make the problem worse. I tried a plug-in to print the bottom 10 mm at a lower speed (30 mm/s as I recall) and that was by far the worst print (the shrinkage/distortion extended the entire 10 mm where the speed was reduced).
I'm not sure what Spiralize Outer Contour is. I'm using Cura 3.2.1 - I'll search to see if it is in play.
Appreciate the input.
MariMakes 201
Hey @minuteman64,
There are three settings that jump to mind when I see this.
A. Regular Fan Speed at Layer
B. Number of Slower Layers
C. Bottom Layers (If you use Spiralize Outer Contour it could be the transition between bottom layers and the walls. )
Can you increase or decrease these settings to see the effect on your printjob?
If this doesn't work it might be hardware related. Than it might be your bed level or even your Zaxis.
