Is it possible to change the toolpath of the inner layer from the outer layer?
Posted
· Is it possible to change the toolpath of the inner layer from the outer layer?
Oh. Just set wall lines to 1 or 2 and it should be what you want. You set walls to zero and that's why there is no outer wall. So increase that value.
You can have a mesh modifier where the inside of the mesh is no different than the outside. And you will still get what I think you want - those intruding walls to strengthen the part.
A year after the merger of Ultimaker and MakerBotQQ, we have unlocked the ability for users of our Method series printers to slice files using UltiMaker Cura. As of this release, users can find profiles for our Method and Method XL printers, as well as material profiles for ABS-R, ABS-CF, and RapidRinse. Meaning it’s now possible to use either Cura or the existing cloud-slicing software CloudPrint when printing with these printers or materials
gr5 2,094
