Missing side menu "object creation"
SEAL_BG
Posted (edited) · Missing side menu "object creation"
Hello,
I try to find the "object create" side bar menu but for some reason it is missing.
I just looking for this menu to show but can't managed to find how to add it - see the picture in the bottom. Is it a plugin or just missing some settings to add in the preferences?
I use Windows 11 22H2 and CURA ver is 5.2.1
Here you are the CURA log too:
cura.log
Edited by SEAL_BG
    Posted · Missing side menu "object creation"
    I think you're missing a plugin. I don't know which one. But "object creation" isn't a default thing that Cura offers.
    Hey @SEAL_BG,
    Welcome to the Ultimaker Community 🎉
    I haven't seen that specific button before, so @nallath is correct, it must be from  one of the plug-ins in the Marketplace.
    I checked your logs and you seem to have a significant number of plug-ins installed. I'm not sure which one you are missing.
    If you click on the Marketplace and then on the gear in the top right corner you can see which plug-ins need an update or which ones are disabled. You can check there which plugin might be missing.
    Hope this helps!
    To add to what @MariMakes said, it could be that one of the plugins you used before has (still) not been updated for Cura 5 and newer, and is not available in the Marketplace for those versions.
    Hi all,
    thank you for the fast answer! Ill will check for updates of the plugins but I think this is not he problem because I already installed the last versions.
    MariMakes
    Thank you for the hints. It's not the only one button missing. The whole bar was not shown and I am not sure why this vase look like icons are not showing at all... and that's why I install all this plugins whit hope, one to repair the problem but for now I am not finding the solution for this problem.
    Thank you all for help. It is not so urgent or important for now. I still use Blender and the new found CAD plugin that extend the ability for object creation.
        • 28 replies
