can you share the stl or cura project file?
Based on how its slicing it appears the model is very much not flat..
I’ve even moved the job through the bed to try and level it, but no change
Hi how do I do that
hi its in sketchup
The issue is with the model, it is very broken. That is causing issues with Cura when you are trying to slice it.
Any way of showing me, it looks fine in the design program
I’ll redraw it again tomorrow
thanks
Morning
ok I sliced the model in half with a square plane, so that surface has to be flat, in cura it looks exactly the same , how can that be?
hi this is the latest one, if you click on the top or bottom surface all is selected
GregValiant 1,364
I took the sphere out
strange it’s ok on ideamaker and not cura
can any one slice it with another slicer to see if it’s only cura
GregValiant 1,364
So what is going on , i have an ender 3 printing from a ideamaker slice and its ok?
GregValiant 1,364
Post a new screenshot of the slice in Cura and what looks wrong to you. I thought it looked good.
Here is your "Phone stand bowling 23.stl" in Mesh Mixer. You can see what @Dustin is talking about. It's that one piece.
This is a view from the other side with the Mesh Mixer Inspector turned on.
Here is the #23 model repaired by MS 3D Builder and sliced in Cura 5.2.1. This looks good but the build plate side of the bowling ball won't come out very well.
Here is a project file with that early model. I didn't pay a lot of attention to the settings other than I did adjust the Line Width to .45.
Check out the file without the sphere, does it change
im using a 0.6 nozzle with a line width of 0.8
GregValiant 1,364
Thanks for all your help, I’ll check it out tomorrow
GregValiant 1,364
Here is a project file. My E3 Pro is the active printer. It's the model without the bowling ball, .6 nozzle, .8 line width.
This is a Cura project file. If you open it in IdeaMaker you will just get the model.
Here is an IdeaMaker project. Remove the ".3mf" extension to open it in IdeaMaker.
phone stand bowling 3.idea.3mf
GregValiant 1,364
When the skirt cuts though the model like that then there is a gap between the model and the build plate. Stiction will be a problem for the head.
Try setting the "Z" to -0.1mm or -0.2mm.
The rotation tool has a "lay flat" tool for models that are slightly tilted. Ms 3D Builder has an equivalent "Settle" tool.
- 1
obewan 37
As a guess i would say the bottom of the model is not flat.
