The red rose looks acceptable, but the model with the lance looks too rugged......no real smooth surfaces through out. Wonder if the quality of the filament is in question. I purchased a $15.00 1 kilo spool and has some layers not smooth or gaps....might also be speed increased in settings menu too high or temperature setting for nozzle incorrect??? When was the last time you lube the rails or cleaned the feeder/nozzle ????
Look at spec sheet on the package for recommended settings do that first.....
Some better images or a better description of the problems you are facing would be great. The "as shown" doesn't really tell us that much right now since it's hard to tell from your images what problems you are referring to.
