Wrong preview Ultimaker Cura
AnaLara
Go to solution Solved by dsp,
Posted · Wrong preview Ultimaker Cura
Dear all,
I have the following problem with the software Ultimaker Cura.
When I segment the model, it does not show the last layer, so preview is not seen rightly.
I think it happens since yesterday I moved the left bar to see the layers, but now I do not know how to repair it.
Thank you so much.
    Sorry @ahoeben, the problem is that the screen does not show the last layer.
    In fact, the model is closed at the top, but in the software the last layer is not showed.
    Please confirm me if I have explained rightly, thank you so much.
    @ahoeben and @dsp, here you can see the original model, the preview and the project.
    Thank you for all.
    Cura.3mf
    I was able to replicate the issue in Cura 4.13 and if i change the from the normal ( 0.15mm layer) to fine 0.1mm Layer the top is starting to show.
    Try making you layer size smaller of make the top thicker.
    wait I was to fast now it still shows on 0.3mm layer height, I need to see what else changed during the change from normal to fine
    Sorry @dsp, but I am not sure to understand you. It happens the same with all the models which I load, indepently of the layer height.
    The last layer (the original model is closed by the top) does not appear when preview, so the model is open by the top).
    AnaLara why do you have Spiralize outer Contour checked?
    If I uncheck it the top layer shows again
    • Solution
    When I read the explanation its normal to leave out tops when checked
    Thank you so much @dsp, I did not notice that this mode was enable.
    no worries happens to all of us every once in a while,
    There are so many settings some get lost in the mass
        • 2 replies
