There was a suspicion that the problem is in the belts, but they are not the problem
and until yesterday there were old belts, I replaced them with new ones, but nothing has changed
Eliminating Strange Sounds from Ultimaker Model S5 3D Printer: Will Changing Motors Help?
Interesting... I am dealing with a noise problem as well. Not the same sounds and not sure who has it worse lol
uffff... that doesn't sound good
18 hours ago, Jhawk6553 said:Interesting... I am dealing with a noise problem as well. Not the same sounds and not sure who has it worse lol
7 hours ago, Tuburni said:uffff... that doesn't sound good
Lol no kidding. Still prints pretty flawlessly. Ordered new belts for all of the axis, bearings for the printhead assembly, and servo motors.
On 3/14/2023 at 12:08 AM, Tuburni said:Hi.
I have a 3D printer (Model S5) from Ultimaker.
And I began to notice that strange sounds appear on it during printing.
These sounds (probably faulty motors) I need to eliminate.
Can you please tell me if this sound will disappear if I change the motors?
Video
Best regards
Its not faulty motors.
The motion belts need replaced. It should not result in print quality issues leaving them as is.
This is common to all generations of UltiMakers to date.
But to eliminate the creaking noise, replace all 4 long drive belts and the 2 short loop drive belts.
These parts are available from your local UltiMaker reseller.
Trust me its madding trying to identify the issue and sounds like a odd root cause when you try to troubleshoot it on your own. But the issue is the belts.
1
The problem is that the belts were replaced with new ones. In this case, following your recommendation, I see two possible problems: I was sold low-quality belts, or the belt tension is too tight
ahoeben 1,767
Why do you think it is (one of) the motors? It could also be one of the belts is creeping up on a pulley. Have you checked the belts?
