It is possible to print 1.75mm filament without any modifications but... you have to print extra slow - probably 25mm/sec top speed. Because the print head has a 3mm diameter in the hot end and the 1.75 - if pushed too hard - will just start coming back upwards and can get clogged in the upper (cooler) reaches of the hot end.
There are 1.75mm conversion kits but really you only need the 1.75mm TFT/TFN part. 3dsolex.com used to sell that - I'm not sure if they still do. aliexpress.com might have some from china although they might not fit very well (those chinese companies aren't great about testing their own product on a printer they don't have).
But really - get some 2.85mm filament. The experience is 10X better.
tinkergnome 926
All Ultimaker printers are built for material diameter 2.85mm. You don't mention if this printer is modified for the use of 1.75mm materials. So that's probably the main reason for the described problems: it's simply the wrong material.
In addition: i don't see a tension indicator at all on the last picture? Are you sure the feeder is complete and correct assembled?
There's a great guide from 3dVerkstan with a lot of pictures:
https://support.3dverkstan.se/article/64-disassembly-of-the-ultimaker-2-plus-feeder
aikimo 0
Thanks, that was a big part of it.. Also, the tension needed to be adjusted..
Thank you for the reply!!
Mo
