On 4/25/2023 at 7:56 AM, Dustin said:Can you please reach out to UltiMaker Support directly and share your machine's log files for this issue?
Guide here: https://support.makerbot.com/s/article/1667337561393
Contact UltiMaker directly here: https://support.makerbot.com/s/contactsupport
I wished I had seen your response sooner.. I got the print to finish finally and left town But I think I may have a clue. Gero's message triggered a thought...
I print mostly with ABS and ASA. To aid printing those difficult materials I set the build temp to 50C in Cura (the highest Cura will accept), and place a blanket over the air manager that large enough to cover down to the bottom of the printer (but doesn't reach the material station). I also have a WiFi thermometer inside the machine so I can monitor the build space temperature. I'm able to see temps around 130F (just over 54C). Although still not hot enough to make really nice parts it's the best I can do, so far. At that temp the air manager fan should activate, but it doesn't always.
I'm thinking that this run, the fan may have activated and the blanket blocked the fan, causing the error. Until I saw Gero's comments I was unaware there was any sensing in the fan....
If anyone knows of a way to disable the fan and sensor, I'd love to hear about it....
Gero 42
We have also had this error several times now. We were able to find out that it is not a connection problem.
For us, the error occurs when the print bed temperature is too low (below 60°C). Apparently the fan has its own monitoring. If it cannot measure the speed of the fan even for a short time, the printer stops printing immediately without being able to continue.
We wrote this to Ultimaker support a month ago. So far, they have been able to reproduce the error once on a printer. However, we have not heard anything further from support.
The error no longer occurs when the filter is removed from the Airmanager. Apparently, the air flow is significantly lower with the filter and thus triggers the fan monitoring much faster.
In fact, we have disconnected our Airmanager from the printer for the time being because we have a few jobs to process and the Airmanager is not contributing to the reliability of the system at all.
As long as Ultimaker finds it necessary to let the firmware cancel the print job completely when this error occurs, I cannot recommend the Airmanager.
Dustin 55
