Oh thank you! Thank you for taking the time to point me in the right direction.
OK downloaded the "Mesh" and "Printer Settings", Synced and restarted. downloaded the model, Left click, - mesh tools - Split the model. But it still has the colour of PETG , extruder 1
Right you are going to think me dumb, but...how do I follow your example and assign the gasket to extruder 2?
GregValiant 1,044
Go to the Cura Marketplace (the button is in the upper right of the Cura workspace) and load the plugin "Mesh Tools". (While you are there, also load the "Printer Settings" plugin.)
Mesh Tools has the "Split Model into Parts" function available when you right click on the model and select "Mesh Tools" at the top of the list. In order for it to work: the model must consist of separate meshes when it is brought in to Cura. I was able to split your model and set the gasket to Extruder 2.
Here I changed the material in Extruder 2 just to make the gasket stand out in this screenshot.
