GregValiant 1,044
5.3.1 with a .4 nozzle
and 4.13.1 with a .4 nozzle
Different models, different continents, same result. A user should not have to deal with that, or with this.
Thanks all for the great response. The "Print Thin Walls" option is a helpful workaround for my case—if I run into further issues as a result, I'll roll back to 5.2.x. Let me know if there's any way I can assist further.
obewan 34
FYI
I sliced your project file using cura 5.2.1 and it sliced perfectly, so it seems to be another problem with cura 5.3.*
Torgeir 217
Hi @spumpsalive,
Welcome in here.
Can confirm your issue with Cura 5.3.1, -but work Ok with Cura 5.3.0 Beta - Xmas version..
So appear it's a "thing/bug" in between those two versions?
Thanks
Torgeir
GregValiant 1,044
I can also confirm.
It's troubling in that this would appear to be the type of bug that indicates that 5.3.1 cannot be trusted.
This is the report on the model from formware.co online stl repair:
--> 0 Naked edges (?)
--> 0 Planar holes (?)
--> 0 Non-planar holes (?)
--> 0 Non-manifold edges (?)
--> 0 Inverted faces (?)
--> 0 Degenerate faces (?)
--> 0 Duplicate faces (?)
--> 0 Disjoint shells (?)
-> Repairing: 100.00%
----- Repair completed in 7378ms ------
-> Vertex count changed from 29547 to 29547 (+0)
-> Triangle count changed from 59098 to 59098 (+0)
This is the first model I've submitted that got straight "A"'s.
EDIT: Looking into this, toggling "Print Thin Walls" on and off will cause that cross-over to disappear and re-appear. In particular the "Minimum Feature Size" seems to play a role. When it is a small number the slice is fine. Once it gets above 0.31 the slice is wrong.
GregValiant 1,044
It was only a question of time. This morning This Bug Report showed up on GitHub.
This is a demonstration model. The slit on the right is .15mm and the left slit is .50mm ( .05mm increments).
5.3.1
4.13.1
In my estimation, they aren't even close. My earlier comment that 5.3.1 can't be trusted would appear to be right on.
Edited by GregValiantLink to post
Torgeir 217
Hi Greg,
right you are, -even ver 5.3.0 has this issue too.
To me it seems like when it come to small details it become worse.
So, if I'll like to try those new versions, I'll always use the monitor to inspect the sliced object before printing.
However, version 4.13.1 is the version I'm using and find very good.
I'm using one small test object, the "ctrl V 3D test" -and if a slicer can do this one well I'll know the UM2 print it fine.
This test object demand using a 0.25 nozzle to be perfect, but can be "some" acceptable using a 0.40 nozzle.
I'll just put up this picture for anyone (Greg knows this very well) to see how accurate Cura could be.
Here's how it's look in the monitor using Cura 4.13.1:
I'm using Cura standard profile, except for the "brim", as I'm using "skirt"
The minimum distance between walls: 0.5/0.4/0.3/0.2/0.1mm.
This test object can be found here: https://www.thingiverse.com/thing:704409
Torgeir
