Or reach out to the creator of the profile or the community for your 3D printer.
GregValiant 1,044
Hi folks. I was just wandering by when I overheard.
Looking at the S1 Pro definition file versus the regular Ender 3 Pro definition file there only appears to be one difference and that is the Z height.
@JCENFORCER if you install a regular Ender 3 Pro in Cura you can change the name to whatever you want. Then go to "Settings/Printers/Manage Printers" and then "Machine Settings". Set the Z(height) to 270.
You should be good to go as the regular Pro has nozzles from .2 to 1.0.
Another option would be to go to the "C:\Program Files\UltiMaker Cura 5.3.1\share\cura\resources\variants\creality" folder and find the "creality_ender3s1pro_0.4.inst.cfg" file. Open it in a text editor and do a Save As simply changing the .4 to .6. Inside the file are two lines you need to change.
Below is the entire contents of your 0.4 nozzle file. You just need to change the Name line and the "machine_nozzle_size" line as shown below. You could keep doing that (SaveAs and change two lines) and make a whole set of nozzles. BUT they may be overwritten the next time you update Cura. The regular Ender 3 Pro nozzles will not as they are included with Cura.
[general]
definition = creality_ender4
name = 0.6mm Nozzle
version = 4
[metadata]
hardware_type = nozzle
setting_version = 21
type = variant
[values]
machine_nozzle_size = 0.6
As I mentioned, the name for the 0.6 file would be "creality_ender3s1pro_0.6.inst.cfg".
Edited by GregValiant-
1
Dustin 55
There is no nozzle sizes because the profile was not contributed with another nozzle size.
UltiMaker does not make these profiles they are provided by the community and get included in Cura's updates.
So the creator of the profile in question never created settings for a 0.6mm nozzle.
JCENFORCER 0
so do i have to upload my own profile?
